june '03 house of the month...little glitter house version..
hello...from warm and humid north florida...summer is here...and the air conditioner in the shop is up and running...
it's almost a new month, too...and time for a new project...this one that has been on my list-to-make for a long time...
here's the link to the pix and images of the original...you'll have to scroll down to june...
http://www.cardboardchristmas.com/papateds/Hom2003.html
my version will be similar...not an exact copy...the pix below is of the house body...all cut out and ready to assemble...
i'm going to follow the same color scheme...this will also be my first "green spot" house...
june 2003 hom lgh version 002-001.JPG (99.68 KiB) Viewed 23181 times
Re: june '03 house of the month...little glitter house versi
Those stairs are going to be cool.
this cries out for coconut!
A great way to start the month of June!!!
here's a pix of the assembled body of the house, roof, chimney, railing/walkway, steps and edge of steps...
i added another slit in the front wall of the house to receive the tab on the steps...making the base is next...
photo 2.JPG (130.87 KiB) Viewed 23153 times
Looking good . . . .
good evening...
it's starting to look like a little house...the pieces are just put in place so i could take this pix...
all the pieces will be assembled with glue after the finish is applied...
Howard, AWESOME, I've wanted to do this house for a long time too. It's looking great, I can't wait to see your finished project!!!!! Will you be using foil? Cant wait!!!!
Brian...
Hope you (and others) will make this house. Feel free to use the pattern. The little squares are 1/4" x 1/4". It should be pretty easy to get the dimensions off the first picture. I wish now I had made my version larger. I'm going to really have to sift my homemade coconut to get pieces that won't hide the railing and step details. I will be using green foil for the chimney as soon as I can find some.
ready for primer and color...blue tape keeps the finish off the cardboard and makes for a better glue job at final assembly...
base measures 4 1/2 " x 3 1/4" x 5/8"...posts are 3/4" tall x 1/4" diameter...fence is 5/8" high...
hope to have finished in a couple of days...
