resizing photos for upload
When you're talking about Cardboard Christmas (putz) houses, a photo is worth TWO thousand words. Here are some notes about posting photos on this forum.
Because the forum software doesn't resize uploaded photos for you, I have to ask folks to make certain they resize their photos to 800pixels wide or less before they upload them.
If you have an old version of Paint (like the one that came with XP) that doesn't let you resize your graphics, try the paint.net program. You can download it at the following link:
http://download.cnet.com/Paint-NET/3000 ... 38146.html
If you go right to the paint.net site, they'll make you download a bunch of other stuff before you get the right file. But once you get it, it's pretty easy to install and use.
Re: resizing photos for upload
1. Find the file you want to resize:
Right click on the file you need to resize:
3. Specify that you want to open with paint.net
4. The Paint.net program opens
5. Click "Image" from the menu bar, then select "Resize."
6. Make certain that "By Absolute Size" and "Maintain Aspect Ratio" are both checked.
7. Specify the new width (for this forum, 800 pixels or less). Note that the height changes automatically.
8. If your picture seems to be a bit fuzzy, try using the sharpen feature. But go VERY easy on it because too much sharpening will cause digital artifacts and look phony.
9. Do NOT save your file over the old one - you may want to use the hi-rez version later. I always rename mine with the new resolution as an appendage. For example, I may have a 250-pixel wide version in a web article, and an 800-pixel-wide version that you can see if you click on the little one. I keep them straight by doing a "Save AS" and adding the width to the file name.
