I’m starting this project off a little earlier than the first of the month…the reason?…it’s A GIANT!…the overall design came from several internet images...my version is not an exact copy either…I did have to “putzerize” the look as well…
The base measures 9” wide by 7” deep by 1” thick…the project may look complicated…but it’s not…there are just a few more parts...some of which are larger than most projects…
I’ll be posting PDF patterns soon and additional photos over the next several weeks…along with details about the windows and door I got from Pete Oehmen…
Stay tuned…
2025 Project No. 3 — Santa’s Toy Shop
- assembled toy shop.jpg (144.71 KiB) Viewed 65232 times
- main body toy shop raw cardboard.jpg (76.25 KiB) Viewed 65232 times
- light holes toy shop raw cardboard.jpg (87.23 KiB) Viewed 65232 times
Re: 2025 Project No. 3 — Santa’s Toy Shop
UPDATE...1-25-2025...
Here is the first pattern sheet...more patterns to follow at a later date...
this project uses the following windows and door...I got mine from Pete Oehmen ---> oehmen@sbglobal.net
ONE Door "A"
FOUR Windows "15DL"
THREE Windows "5L"
ONE Door "A"
FOUR Windows "15DL"
THREE Windows "5L"
1 t s pattern sheet.pdf- (55.67 KiB) Downloaded 1315 times
UPDATE...1-27-2025...
Here is pattern sheet 2...see PDF below...stay tuned for more patterns...just a few notes...the window sills are ordinary kitchen matches...the roofs and the chimney cap will be covered with white cotton batting...a "full cotton topper treatment"...pictures later...
2 t s pattern sheet.pdf- (50.88 KiB) Downloaded 1348 times
Looking terrific, Howard...a complex design. I look forward to seeing your incremental progress (and thanks for the schematics)!
UPDATE 1-29-2025...
Here is pattern sheet 3...note that the width of the back...(noted as 5 7/8" on pattern)...may need to be adjusted depending on the way the other score and fold lines grow...a small change in location of score and fold lines and the thickness of your cardboard could possibly change the width up to about 1/8" or so...perhaps a little less...
- light holes toy shop raw cardboard.jpg (134.64 KiB) Viewed 65001 times
3 s t pattern sheet.pdf- (69.23 KiB) Downloaded 1294 times
UPDATE...1-31-2025
Finished up the "cotton topper roofs" for the project...painted the raw cardboard roofs white before covering with cotton batting...still have to trim the batting a little where the main roof meets the second story...after final assembly, I'll give selected areas of the roofs a blush of glitter...stay tuned...
- santa toy shop roofs.jpg (89.61 KiB) Viewed 64759 times
- santa toy shop roofs touching.jpg (79.29 KiB) Viewed 64759 times
UPDATE...2-12-2025...
Finally getting back to painting Santa's Toy Shop...had to go with red and green...the single-face corrugated trim will be painted metallic gold...may paint the kitchen matchstick windowsills metallic gold as well...ignore the metal C clamp...it's attached as a painting handle...stay tuned...
- santa toy shop painting.jpg (116.25 KiB) Viewed 63787 times
So looking forward to this one!
UPDATE...2-26-2025...
Santa's Toy Shop is open for business...almost...I have several options I'm working on for the sign, Santa and elf figures...hope to have it figured out by Christmas...I'll post an updated picture later...
Stay tuned...there are more projects in the works...
- santa toy shop finished no sign or figurines.jpg (263.88 KiB) Viewed 58646 times
Antoinette
Knock-down gorgeous, Howard. (I hope you realize how intimidating the "before" picture is!)
--Antoinette
--Antoinette
