This is the second house I've made with the Sea-Worn Beach House pattern. Howard suggested that I make a palm tree to go along with the beach house so I did. And the palm trees are absolutely perfect. I made them a bit different from his trees which you can read about here - http://littleglitterhouses.com/paul/pal ... mtrees.htm. But really the technique is very similar. Thank you so much for that suggestion Howard.
You can read about making this little Putz house by the Sea "She's Seen Better Days" - that's the name of the little house. The free pattern is available on my blog. https://paperglitterglue.com/make-putz- ... y-the-sea/
Little Putz House by the Sea
- Pink Sea Worn Beach Cottage with palm trees paperglitterglue.jpeg (91.31 KiB) Viewed 15386 times
- Back view pink sea worn beach putz house with palm trees paperglitterglue.jpeg (105.16 KiB) Viewed 15386 times
Re: Little Putz House by the Sea
I live the beach and water supper job!!
lucy...
you have certainly demonstrated just how many different looks you can get with one pattern!...and the palms are the perfect accent...you know what?...i should probably send you a pair of pink flamingos to go in the front yard!...and i will...just as soon as i can fine where i "filed them"...
i know they are in the shop somewhere...
That's a great one Lucy!! The beach is AMAZING!!!
