A Halloween House
A Halloween House
Since Will made a house, I need to make one too.
Looked like fun.
My wife is a Stampin' Up demonstrator.
She got a die set that had a house with different windows, doors and roof pattern.
I "borrowed" for a bit and cut out a house.
I then "Putz-ized" it.
Added a few embellishments.
The witch in the doorway is from Howard's website.
Going to be in the 30's tonight in Vermont.
Feeling like Fall already.
hween 800.jpg (278.4 KiB) Viewed 29063 times
Happy early Halloween !!
Re: A Halloween House
Sweet Halloween house Steve. You nailed it! Did you use luffah for leaves? Awesome piece of work.
Will
Steve...
the "black glitter bark" on the tree is a neat idea...i was also wondering about the leaf material...let us know...
Great house, I love Halloween putz houses!!
The leaf material is a product called flower soft. A bit pricey but a little goes along way.
Making your own "flower-soft"
https://www.youtube.com/watch?v=D_tz3P9NOcY
That is one fancy Halloween House. It's nice and happy too.
Just a note about the homemade "flower soft".
What I figured out after making my own using the method in the like Maria posted.
It is not styrofoam, but urethane foam that is ground up to make the base material.
I tried making mine w/ urethane foam, and you get the same look of the final material.
Question Steve:
Is the urethane foam the same stuff that foam "egg carton-style" mattress toppers are made out of? Thanks for your answer in advance!
Cheers,
Will ~
Yes, Will.
