just couldn't resist making a couple more "flatties"...these were inspired by a couple in a set of vintage model railroad figures from way, way back...probably pre wwll vintage...although there have been reissues by a couple of makers since then...
one of the projects i have in the works for 2016 will be a small railroad station...and perhaps a few more "flatties" to use around the station...probably a porter, conductor and an engineer...
have a great new year...
making "mr. and mrs. traveler" flatties...
- mr and mrs travler.jpeg (87.84 KiB) Viewed 24127 times
Re: making "mr. and mrs. travler" flatties...
They are perfect... Can't wait to see the painted travlers...
What is Mr Travler carrying?
Debbie W
Debbie W
back then, it would have been called a "valise"...today, i guess we'd call it a "carry on"...debquilts wrote:They are perfect... Can't wait to see the painted travlers...
Debbie W
i may add a piece of luggage to mrs. travler...perhaps a "hat box" or a "train case"...
greetings...
a quiet afternoon...and time for some xacto knife work...the profiles are ready for "layering" details...hat brims...coat and collar trims...hands...luggage...also need two simple oval bases and a few craft wood braces...more later...
- mr-mrs-travler-flatties-blanks.JPG (175.63 KiB) Viewed 24091 times
Re: making "mr. and mrs. traveler" flatties...
first...old howard has got to learn the correct spelling of "traveler"...
these two are ready for mounting on painting sticks and a couple of coats of primer...then the fun part...adding color and detail...
i see a few things i'm going to trim slightly...also note i added a "hat bag" to mrs. traveler...
- mr-mrs-traveler-primer-ready.JPG (202.09 KiB) Viewed 24071 times
Howard,
Those are incredibly detailed flatties. Of all the things you show on this forum, the flatties look the most difficult to me. Do you cut them out with an 11 blade? And you may have gone over it in a previous post, but how to do mount them to your paint sticks? Mostly I paint my fingers as they are the paint sticks for me.
We look forward to seeing Mr. and Mrs. Traveler on their way.
correct...#11 xacto...but the blade must be sharp...note...i also wear a magnifying visor or a pair of 3.00+ reading glasses...
painting sticks are pictured below...about 5/8" square by 6" long...flatties are held on with a dab of hot glue...i gently peal the flattie base from the top of the stick when finished priming, painting, detailing, clear coating and adding glitter on the snow...
- travelers-mounted-paint-sticks.JPG (138.39 KiB) Viewed 24047 times
I'm enjoying seeing your 'flattie' collection grow. I especially like the layered effect on your figures.
here is a REVISED picture...i did add a newspaper to mr. traveler's right hand...
my very best regards...and a happy new year to each of you...
- travelers-revised-newspaper-added-001.JPG (218.23 KiB) Viewed 23974 times
What a nice looking pair of travelers!!
