Putz Progress Wilkins House
Re: Putz Progress Wilkins House
Lynn,
I just can't cut windows like you guys do. I always use a die. This is my favorite window frame of all the dies I have. It's on a Sizzix die called Village Manor https://www.sizzix.com/661591/sizzix-bi ... lage-manor. Right now it is only available as a part of a bigger die to make the manor, but I think later in the year they will introduce as a smaller set with multiple windows that you can cut out 4 at one pass through the die cut machine. I've included a photo from the Sizzix website (with link).
John,
You inspired me to look a lace as a possible base for the balusters. The lace die I have was too big for the railing, but I did use it as fencing. And then that led to the offcuts for balusters. I have a modified
variation in mind for the "real" Wilkins house.
https://www.sizzix.com/661591/sizzix-bigz-l-die-village-manor
village manor die window.jpg (6.12 KiB) Viewed 15504 times
Wow - a lot of work is going into this project. I can't wait to see your final house. And I'm interested in hearing your lessons learned. It's always a learning curve, isn't it?
Thanks Lucy for the info and the window :)
Laney
Post by Laney »
Catching up on my forum reading and was happy to see this here. As you know I have seen it on your blog but it's good to look at it again - this is quite the project! I am sure the Wilkins House will turn out well.
A couple more photos about progress on this house.
I finally wrote a blogpost about lessons learned from the prototype:
1. How to make a tower to fit a hipped roof - sort of learned this. Still working on the geometry.
2. How to draw a steeple pattern - I posted that in a tips and technique post when Paul had a reader ask about making these patterns.
3. How to make a second story porch or rather how NOT to make a second story porch - I wasn't very happy with the crooked front porch on the previous house. I have been much more meticulous in measuring on the real house.
4. How to cut small dowels to length - now I use a dremel tool to cut dowels better.
5. How to make a solid porch floor - using the Howard method with stacks of corrugated cardboard covered by a piece of smooth cardboard.
6. How to make folded cardboard stairs - I'm going to score the steps and add the sides separately to avoid the seams from folding the stairs.
7. How to make porch railings - measure, measure, measure.
8. And most important, do the hard things first. I learned to do the tedious details first while the project is somewhat fresh.
https://paperglitterglue.com/spring-man ... prototype/
Many, many pieces that needed painting for the Wilkins House
Pieces that need painting Wilkins house.jpg (77.83 KiB) Viewed 15447 times
Test fitting pieces together for the Wilkins Putz house.
Wilkins Houses almost done.jpg (74.32 KiB) Viewed 15447 times
