October is a new month and time for a new project…it’s another in the series of Dolly Toy Company “Printie” inspired reproductions I’ve done over the past several years…go here for others…
https://www.cardboardchristmas.com/foru ... =10&t=2221
Since there is a limit to the number of attachments per topic and replies, I’ll be posting multiple updates with the graphics for walls, chimney and roofs plus more info…stay tuned…
2024 Project No. 13 - - Stone Printed Cottage with Side Room
- graphics walls.jpg (233.04 KiB) Viewed 34697 times
Scan_20240922 (3).pdf- (84.47 KiB) Downloaded 1141 times
Scan_20240922.pdf- (156.44 KiB) Downloaded 1183 times
Re: 2024 Project No. 13 - - Stone Printed Cottage with Side
UPDATE...10-2-2024...
Here are the graphics for the stone walls, roof and chimney...you will need to print two of the stone walls...see the diagram of how the stone wall graphics are used to cover the cardboard walls...
Note...I hope these files open and print at the correct size...they may have to be opened and printed at a different percentage of original size...
stone walls.pdf- (2.43 MiB) Downloaded 1153 times
roof green.pdf- (2.23 MiB) Downloaded 1126 times
red bricks antique.pdf- (2.32 MiB) Downloaded 1190 times
UPDATE...10/3/2024...
It's starting to look more like a stone cottage...stay tuned for more...probably a picture of the finished cottage at end of week...
- stone graphics on cottage assembled.jpg (148.01 KiB) Viewed 34650 times
- brick chimney assembled.jpg (93.17 KiB) Viewed 34650 times
UPDATE...10/5/2024...
Another project completed...and I must tell you that the finished cottage looks better than the photo...and as usual, I'm second guessing my color choice for window mullions...should have used a color with more contrast to the stone graphics...
Stay tuned for a couple more projects in 2024...
- stone cottage finished.jpg (191.71 KiB) Viewed 34603 times
